I've got that and it's fine, I can't tell it apart from the Murex one which came with the machine, but I don't do much welding so I'm not a great judge.I've just bought a single stage twin gauge one from Weldequip, not the cheapest but not too dear either I hope these are ok.
I disagree (sorry maker) with above. Spend what you have and a bit more. Regs even for the hobby user are put under the same 230bar pressure as in industrial use. A 2 stage reg is more money but will save you on gas usage so that initial layout is paid back over time. Gas flow has a massive effect on weld quality also. You can spend £3000 on a machine but if its married up with a £20 reg that doesn't perform well you're going to be getting inferior results. I'm very fanetic about gas equipment and in my experience its seen as a secondary priority by many people. Good quality reg with good fittings and good gas lens will make all the difference to what you put down on the metal and buy its self back in gas savings.
Cromwell have single stage Murex regs for £80ish.If you look on the Murex site go to Gas Equipment, in the inert section you will see an Arc 2 Tig Regulator.If this is used with a flowmeter you can adjust the pressure by the adjustment device on the flowmeter.This is one way of keeping the pressure constant
Do you know how accurate these are? I'm always a little bit sceptical of it when I use it.dirt cheap 'peashooters'
It it is not calibrated it is not accurate!!
