Gavin Melville
- christchurch, New Zealand
I needed to tig a tube of silver steel to the same thickness (5mm) of gauge plate. Everything, and there wasn't much, said to use 312 filler rod, and keep the heat down. Did that and after two weeks of fairly hard use the gauge plate cracked 0.5mm from the weld. I'm guessing this happened at the edge of the heat affected zone. I didn't need any further heat treatment, the steel was hard enough as it was.
I don't have a photo, I've had to re-weld and put back in service. Think a cotton reel with a big centre hole sitting on top of two matchboxes.
I've found out that what I buy as silver steel (no silver haha) is also called O1 oil hardening tool steel.
Does anyone have experience welding tool steels?
