BChild
SIP - enough with the mods!!!!
Rather than put this in the SIP section I thought I'd ask in here
Tonight I ran out of normal wire 0.8mm right in the middle of a job that was all clamped up (had some gas less wire left that came with the machine and was quickly ditched after it kept birds nesting with the rubbish std feed) I wanted to finish a plate where it wouldn't get seen so swapped the polarity and spooled it up with gas less
Straight away I ended up turning the welder down to the absolute minimum and still it blew holes - it's like it's had the amps doubled!!!
This doesn't equate to me as surely flux cored wire has less metal so it should more equivilent to 0.6 mm wire and be lower amps!!!
Am I not thinking straight here
I swapped to pull rather than push - didn't make any difference
When it didn't blow holes you could get a lot of penetration and a good bead of weld but it didn't make up for the holes.
Anyway I've now used it up so I never have to consider it as an option again - big spool of wire time after all the damn Mini is gonna be using a lot!!
I'd like to know why it seemed so over powered tho!!!
