I have a Dayton 160 amp mig welder model #3Z914E. My problem is I turn on the machine, turn on the gas and then hit the trigger and no gas comes out of the solenoid to my gun. I turn off the gas and bleed it and then hit the trigger and the solenoid opens and closes with no problems, but not when there is pressure against it. I've also hit the trigger to open the solenoid and then open the gas and it flows good through the gun. When I let go of the trigger the solenoid shuts off the gas and then I hit the trigger again and it wont open. I measured the voltage to the solenoid and getting a -12.7 dc volts when I hit the trigger, the solenoid is a 24V-DC 6 watt. What do I check for? Need to get this going to finish my project.
