F flash69 New Member Messages 3 Nov 3, 2011 #1 hiya all, was just wandering if anyone can tell me if it is possible to convert my mig welder to gasless and if it is what do i need? thanks,
rtbcomp Moderator Messages 18,573 Location Sheffield UK Nov 3, 2011 #2 Welcome to the forum. We need to know make & model. Are the connections for earth and welding torch easy to swap over?
F flash69 New Member Messages 3 Nov 4, 2011 #3 rtbcomp said: Welcome to the forum. We need to know make & model. Are the connections for earth and welding torch easy to swap over? Click to expand... thanks mate, its a draper mig weld 100, everything seems quite easy to get to
rtbcomp Moderator Messages 18,573 Location Sheffield UK Nov 6, 2011 #5 If you need to dive inside the machine to swap the earth & torch leads then it's not suitable for gasless wire, if the connections are on the front panel then it is.
P philsmin Member Messages 221 Nov 6, 2011 #6 If you were to change internally you'd also need to change the switch configuration so that the trigger still works. My clarke 90EN (gas/gasless) has 2 wires going to the trigger switch, my 150TE has only one wire and uses the feed to the torch as the other wire. You could just try it as is and see how it is, some welders don't seam to fussed about the polarity change.
