Monrovian
We used to wadge a small piece of steel wool up the pink straight ceramic around the tungsten (only a loose ball about 10mm round) that you would usually use for alu and use that on stainless steel. I found it worked better than the lense which i also had, if you wanted to get in a tighter corner. The lenses are quite chunky afterall. Cost **** all as well which was a bonus.
