Hi,
I have an old Hobart Handler 120 - a 90amp welder that gets good comments (the model before Miller redesigned it).
When the trigger is pulled, not only does gas come out of the tip, but it is coming out of the output wire guide, i.e. where the wire goes after the roller. Is this normal?
With the gun disconnecet from the welder, if I blow into the liner at the feed end, air does come out of the orifices where the gas feeds into the 'plug' , so it is not a question of the plug O rings not sealing - it is leaking from inside the plug into the liner. As I say, I don't know if this is normal. The liner is a coiled spring in excellent condition. The parts list does not show any seal between the liner and the output wire guide.
Thanks,
Clive.
Thanks,
Clive.
