empty cylinder more like especially with 2 regs triedI'm Having trouble getting my argon regulator to get above 5 lpm' I swapped regulators & got the same reading, I then put a pea shooter on the end of the torch & still a low reading. Would this point to a gas leak somewhere ?
cheers
my guess would be gas solenoid then, take the case off remove the gas pipe at various stages until you have free flow then you will have found your restrictionTried 2 new bottles so not that, machine is a murex tig welder
have you removed the gas shroud and checked for spatter build upOk thanks for that I will take look at work tomorrow and see what happens.
it could well be fullNo but will do
It's a Murex tig so there shouldn't be that much spatter. You are showing mig parts snoop![]()
Must take more time to read properly
the fact he said argon should have also told me it was tig, must have been half asleep that's my excuse and I'm sticking to it
