C CA121 New Member Messages 3 Jul 26, 2008 #1 Hi. what gas would be best suited for welding 2.5 mm mild steel. co2 or co2 / argon mix? if the latter what sort of % mix many thanks
shenion Tool Pack Rat Messages 7,586 Location Stone Mountain, GA USA Jul 26, 2008 #2 Ar/CO2 mix would give cleanest weld. CO2 will work. Ask you gas supplier. Each has their own mixes. They would probably recommend ArgoShield Light or an equivqlent. Here we would use 75/25 Ar/CO2, we use that for most uses.
Hitch Moderator Staff member Messages 13,576 Location England Jul 26, 2008 #3 Co2 argon mix gases vastly out perform co2. For stuff like that a 5% or there abouts would be ideal, so if your going down the BOC or AirProducts route, thats argosheild light, or coogar 5.
shenion Tool Pack Rat Messages 7,586 Location Stone Mountain, GA USA Jul 26, 2008 #4 Hitch said: Co2 argon mix gases vastly out perform co2. For stuff like that a 5% or there abouts would be ideal, so if your going down the BOC or AirProducts route, thats argosheild light, or coogar 5. Click to expand... 5% is fine if it is tri-mix, not for Ar/CO2. 93/5/2 Ar/CO2/O2 is equivalent to about 80/20 Ar/CO2 (or maybe 85/15). Remember the O2 is about 5 times as effective at adding heat than CO2.
Hitch Moderator Staff member Messages 13,576 Location England Jul 26, 2008 #5 I was simplyfying it... argon/co2 mix, such as coogar/feromaxx/argoshield, are tri mixes, quite right Shenion. I meant 5% mix of the above.
shenion Tool Pack Rat Messages 7,586 Location Stone Mountain, GA USA Jul 26, 2008 #6 Hitch, did not mean to criticize just did not someone to search this thread and think 95/5 was for thinner metal (used here for >200A).
