swordfish210
Hi, i'm having more trouble with my 135TE (the things causes more problems than it fixes
) I was previously having issues with the wire feed but thats all fixed now, only trouble is i can't seem to get any gas out of the thing.
The gas regulator i bought it with was seized solid so i bought a new one from Weldequip like this one
Which broke almost immediately so i got myself an SIP regulator a bit like this:
Which has an identical pin to open up the gas bottle so i assumed it would work fine. I know the bottle has gas in it because the SIP reg has a bleed hole so as you screw it in you get some gas purge before you tighten it up fully. Despite that when i undo the valve i get no gas flow out of the pipe. I thought it was a blockage in the pipe but i can see now that isn't the case as i cut a bit of pipe off and pushed in to the reg and opened it up and got nothing
Any ideas what it could be?
) I was previously having issues with the wire feed but thats all fixed now, only trouble is i can't seem to get any gas out of the thing. The gas regulator i bought it with was seized solid so i bought a new one from Weldequip like this one
