reliant-reviver
New Member
- Beighton, Sheffield
Hi,
have drawn a blank searching the forum on this so I was hoping i could pick your brains.
My old trusty Clarke 185E mig has developed a gas feed problem. The moment the unit is switched on the gas starts feeding regardless of the trigger. I recently replaced the MB15 torch, so am confident that is not at fault.
I have removed the side casing, and to be honest it's all quite unfamiliar to me, I have located the solenoid and visually checked the wiring to it. With a wire removed the gas feed stops, does this suggest the solenoid is kaput? is it a powered close or powered open valve?
Thanks in advance, Phil
