hi all. im new to the forum and just after some advice.....
Ive been welding for years, and never needed a welder at home untill now (car restoration) and my boss has had an old murex tradesmig 165 sitting around doing nothing, so i asked him if i could have it, few pound notes later and i brought it home.
now the problem is gas; i have a regulator for it so can use the normal bottles, but the trouble is where to get one, i had a word with our supplier and he said you have to hire the bottle (at about £30 a month) and then pay about 60 quid every time you fill it up, now not only is that a stupid amount of money, i wont use it often enough to warrant doing that.
so (my rather long winded) question is how do i go about fitting disposable bottles to it? or where do i get a proper bottle at sensible money from?
many thanks in advance
) 4mm plastic pipe.... as fitted to most portable units, more up-market unit will probably have a connector fitted to the units body, in which case you need an adaptor pipe with the relevant fitting... any welding shop should be able to help, our local one even carries loose "fittings" so you can make up your own.
