You would be better with it outside, don't really want pipework at bottle pressure
Yup, I think I will be going with the two regulators option...
Probably dont need 2 unless you have a massive pipe run, maybe a pea shooter one at the machine and turn the outside one up a bit
That would be an option for the shielding gas but not the propane, oxygen and acetylene...
Propane wont need a second reg will it?
Just put a quick-connect or camper type bbq point on the wall somewhere for that
No experience with oxy or acetylene but Propane is something I know about. Really no need for a secondary regulator unless you are running 100m plus of 15mm pipe and really really do not have any bottle pressure pipework, it will not end well
should work as long as u get the ball valve suitable for gasshould work as long as u get the ball valve suitable for gas
don't even go there extending themEasy enough for propane, oxygen and acetylene is another matter...
