N naughtyboy Guest Jan 29, 2013 #1 just want to check before i start that tap on a propane bottle is left hand thread. cheers.
rtbcomp Moderator Messages 18,573 Location Sheffield UK Jan 29, 2013 #2 The hole you screw the regulator in on the red propane cylinders is left hand. Have a look on the nut on the regulator, it should have nicks cut on the corners of the flats to denote a LH thread. Last edited: Jan 29, 2013
gordon stephenson Member Messages 7,468 Location Skelton in Cleveland U.K. Jan 29, 2013 #4 As rtbcomp says the regulator thread on the valve is left-hand, but if you are wanting to remove the whole valve for making a log burner or BBQ etc the valve is screwed into the bottle with a normal right-hand thread,
