I get my pub gas bottle refilled co2.. But in use after just a few mins the guage freeze up and output of gas stops causing welds to be rubbish or OK for first minute... The pressure reducer is one with vertical plastic sight guage with knob to adjust output
Tia
Your bottle probbley has a dip tube,so is pulling the liqued CO2 up. It's the same with using fire extingushers (as I do) so you end up having to use bottle up side down. Even then you may still get frosting up of the gauges.
Does your bottle have a white stripe painted on it?
You need a pub bottle without a stripe (or a co2 fire extinguisher - i used both, and they both fit the same gauge)
I was told that's a stripe is a sign it has a dip tube inside, explained above.
