Park_monkey
Hello all.
I have a double concrete section garage/workshop that i am in the process of making some alterations to.
I got planning permission to raise the roof a couple of foot as its too low at the moment to be really usefull and once that is done i will be insulating it and lining it.
I have a load of rolls of insulation that i acquired when i worked on site a while back and a good stack of reclaimed, plastic coated, box profile sheets. They are actually the lining sheets that go on the inside of commercial buildings so i was originally thinking they would be ideal. After reading up on the subject I am a little concerned I may have a problem with condensation if i use these sheets!
I get alot of water dripping from the roof at the moment at its only a thin corrugated tin roof so was going to insulate that too.
My plan is to-
-silicone between all the panels and lay a fillet of cement round the bottom.
-stick timber batons to the panels then line the garage with visquine.
-fill in between the timber batons with the fibreglass insulation.
-fix the lining sheets over the top to the timber batons.
is there anything else i can do to prevent condensation or am i better of scrapping the sheets and using plasterboard or ply?
Any advice greatly appreciated, I really need to start making the most of this garage rather than it just being full of crap all the time.
cheers.
My plan is to-
cheers.
