I want to make my existing single garage double width. But neighbours...... They aren't exactly the neighbours from hell but we don't get on (most of the street cheered when the for-sale sign went up but it didn't sell and they've had a loft conversion instead). I generally manage to avoid any problems by just keeping my head down and ignoring them but every once in a while they'll do something that just makes your jaw drop in dis-belief that someone could think it was acceptable behaviour. My extension would fall within permitted development so there's little or nothing they could do about it but in the interests of a quiet life I'm thinking of doing it piecemeal to ease them into it.
My plan is to build a "pergola" up against the existing garage. I'll then stick a roof on it to make it a car-port, then I'll box the sides in. Ultimately I'd like to ditch the existing concrete sectional garage and make it a single integrated structure by mirroring what I'm proposing as the extension. But it's also in my mind that this might never become more than a car-port.
I've looked at ally framed car-ports but the prices seem silly for what you actually get so I'm thinking of making something myself. So far (and I stress this is a fluid plan - hence asking opinions) I'm thinking 100mm square 3mm wall box section in steel. I'm thinking a vertical at each corner and horizontals between them - it's a shade under 5.5m long and width-wise is to be determined but I'd guess 3m max. What's the opinion on the strength of my "beams" over those lengths - do we reckon they would support a roof (single pitch near flat).
Raising the corner uprights.... Concreting them into the slab would be ideal I'd suppose but I do want this to remain a modular/flat-pack thing that may go back to being a single garage in the future so I've been wondering about these Metpost things that everyone here seems to love so much - specifically the bolt down ones. If I bolt one down at each corner with anchor bolts do we reckon it would be enough to hold the structure down? I'm thinking along the lines that the existing garage is pretty much just sat under it's own weight with very little in the way of fastening between it and the slab.
Also along the lines of my stealth/piecemeal plan What's the opinion on making the base in separate pieces? I'd like to put bases in for the corners and have them in place but then add the centre later so that it's not obviously going to be a carport/garage from day one. Maybe rather than 4 separate pads two trenches at either end becoming effectively foundations would be more sensible.
Iain
Iain
