Grrrmachine
Here's the little brick lock-up I do all my car work in. My BMW E30 just fits in there each day, protecting it from the -30 winters we have. It has a single 16A fused ring for sockets and lights.
Up until now, I've just done rattle-can painting and drilling in here, but now that I've got a welder and compressor, I need to sort out an air in-and-out system for spray painting and dust/fume removal. As you can see on the right, there is a 140mm square air vent, no fan, going through a 250mm thick rear wall. The doors on the left are wooden, with small holes drilled in top and bottom.
I was planning on wiring in an extractor fan (150mm, 200 m3/h, more than a Sealey extractor) to the vent, with some ducting to extract air from the sides of the garage. I will then run a smaller duct to the door end to meet a hole in the door, to feed the compressor, which, irritatingly, will be sitting just to the left of the ventilator hole. This is so that the compressor doesn't suck in any of the fumes expelled during painting. Good idea, or have I ignored some drawbacks?
