Shedendman
Didn't know where to ask this...................so here goes
I have some gal plate i want to weld up to more gal plate,in other words i've loads of 1.5mm thickness but need to make up some 6mm thickness(its for the hotplate on a woodburner) now i know that galvanize is nawty stuff to weld with so how much of the coating do i need to grind/sand off,back to shiney steel ie gone the dull hammer/fish scale effect,i dont want to use a grinding disc as this is far to rough,sanding disc with 80 grit perhaps??????
Another thing i intend drilling loads of 6mm holes in 3 of the plates place them on the 4th and plug weld them then do the edges this a good idea????????
So basically 4 bits of 1.5mm sandwich together to make a 6mm plate
All ideas welcome
All ideas welcome
