My year 2001 Discovery ES TD5 is beginning to show a little chassis rust either side of the fuel tank - got though it's last MOT ok but needs sorting. Other than this it's in pretty good nick. I've had it since it was two years old, and it's done less than 75K.
I'd intended to trade it in and get a slightly more modern Defender, but for the use this gets (towing stock trailers back and forth to the abattoir) I'm coming to the conclusion it's worth sorting and keeping for another decade.
My local Landrover man is suggesting pulling the bodywork off the chassis, fixing the rust issue, then galvanising the original chassis and putting it back together. (fixing the rust only requires dropping the tank)
I quite fancy this suggestion, but I'm slightly sceptical that you can clean a used chassis well enough for hot dip galvanising. After all they tend to rust from the inside outwards, so zinc spraying / Metco spraying the outside is barely worth doing.
Anyone any experience of galvanising a used Landrover chassis ????
