Hi all.
The only 2mm plate I could find for a repair needed on my car is galvanised. Can I just grind off about an inch broad strip where I will be welding, or do I have to be more drastic? any advice would be good. I was also given a large 2mm plate of the same stuff for practice on, a bit over the top but it was all he had handy.
The 2mm plate for the car is shaped for the job and he had to weld a 6" bit on the end, he has that bit a bit shiny where he has ground off the galvy around where he was welding, so I thought that was all I'ld need to do too.
Bigrab.
Bigrab.
