Would in a heartbeat if I had a) money; b) somewhere to put it.Buy a lathe?
I likes this solution, it involves weldingWasher with hole slightly smaller than diameter of ball. Slit with hacksaw, bend and helix into place. Make it flat again.
Nut that has ID slightly bigger than OD of ball and height roughly the same as ball diameter. Drilling out the threads of the nut is a bonus.
Flat plate with OD slightly bigger than across points dimension of nut.
Weld as required.
