Fintray
- Aberdeenshire (UK)
Yes it is.
Would it be possible to send me some of the data and a description of what type of charts you were hoping to get?
Yes it is.
No chance! The next generation of freezers will probably sense the mains frequency and switch on when demand on the grid is low, ie when the frequency rises slightly. This coupled with a Very Smart meter will give the consumer a variable tariff.
So far this freezer has taken nearly 17 hours to freeze 3 litres of water, and the outside panels feel quite cold, so unless I can add extra insulation I doubt whether my Cunning Plan will work.
There's a lot of condensation on the outside,.
Has it got a condenser on the back, if it has you will be ok to pin on more insulation, plus put some over your food under the hatch.
I think that means that the barrier around the space containing the insulation has failed and it's become waterlogged internally. Insulation no longer doing its job to an acceptable degree hence the condensation on the external surfaces.
Julian
Not sure on that one, what does it look like and why is it significant?
