octo0072000
- south yorks
do you get any vibs at all with the prop off as said rover 25/45 is the same box set up apart from the pto for rear prop
they are now getting some problems with inner cv joints causing bad vibs
but if your front half of rear prop is running out of true could be the cv joint in the prop causing it
can you split the front half of prop off leaving the rear half vcd diff etc on and try it that way
