. To be frank though I bet you can buy them cheap enough (my mate has a chandlery and has had me look at a load of stuff for making and its not ever worked out viable cost wise). if I had to make one I should do away with the taper and just use tube and a stronger design welded joint at the topDo you have a Flypress?How would I form the tapered tube part of this boat pole head ?
Its 40 mm at the big end. And maybe 2 or 3 mm sheet.
