if i wanted to 100 x 100 x 6mm 90 degrees what length would i have to cut at. e.g when forming does it stretch the material at the bend or use material.
With a lot of things that are critical, we would calculate the cut length of the material and set the backstops, then do a test bend. Easy to then alter the length and/or position of the bend by a mm or so as necessary.
Some things you need to get right first time though!
