Just a quick question. My Ford 655C has a shuttle shift for forward, neutral and reverse. It all works but it seems slow. I can change from neutral to forward and it will take maybe 4 seconds and a small jerk to engage drive. Same for reverse. I can deal with this and reduce the jerk as it engages significantly by shifting the shuttle lever with the clutch neutral button held (its on the gear and front bucket lever), hold the foot brake and then release the clutch button, let it gently engage and then lift off the footbrake.
Is this delay normal. My neighbours machines with similar are much newer but change quicker and with less of a jerk. It just strikes me its a little slow and jerky. Trans fluid levels are fine and I have changed the trans filter but no real change. I suspect a drain and refill is next but is there anything else to look at, especially while it is drained?
