german8rcoupe
I would be up for one of those if you wanted to double up on an order and maybe split carriage? In fact, Langy may be able to bring it in?
I'm guessing you did eventually find out your wiring for the R-Tech foot pedal wiring. Just in case anyone else is after it here it is (from a 2014 machine and pedal).
The connector is a 7 pin Weipu WS16-7 with a TQ style clamp, it's apparently an aviation connector for pilots headsets.
The switch is connected across pins 1) & 2)
The pot is a 50K linear pot and connected across pins 3) & 5) with the wiper on pin 4).
There are also two 0.01uF ceramic capacitors, they are connected directly to the pot from the outside connections to the wiper connection, I assume to surpress interference. (so one between 3) & 4) and one between 4) and 5) )
Pins 6) & 7) are directly connected to each other in the plug.
On a torch switch
only pins 1) and 2) are used, pins 6) & 7) are not shorted together so I assume this is a connection to say whether or not there is a remote pot.
