ghostdancing
- italy
my machine comes with a footpedal that has a potentiometer knob..what is the use of it? i tried to turn the knob but the amperage seems to be not affected at all
amps display on my welder only works with the pedal unplugged from the sock, when i plug the pedal both amp knobs on the machine and pedal do not work and the display just shows 10 amps (minimum current available)
other from that the pedal works well, but i must set the max amperage before connecting the pedal to the sock on the front panel
i also found a post here where the user was talking about the same particular behaviour of this welder set..so i know that this is not a problem of my example, but an (annoying) feature of this model
