Tiggy_dorset
It looks just like a bought one!
- Weymouth, Dorset, UK
Hi guys,
have a Clarke tig150 (scratch start). Although it has no HF option, is it still possible to add/adapt it for adding a foot pedal, or at the very least a push button. I expect the answer is no, unless I get involved with modifying the elecronics inside. Simple electronic mods I can handle, but I dont want to get too involved with it to be honest.
This model has a continuouse gas feed controlled by a knob on the torch. I dont like to waste gas (and energy switching the gas on and off vie the bottle) so I am also thinking of buying a foot operated gas valve/switch to switch the gas on and off when needed. Sounds simple enough, is there anything I should take into consideration with this option that I may miss?
Cheers.
Cheers.
Yes Paul you are right. I have only used this machine once a long while back, with a crappy regulator with no guages, and one of them (dare I say it?) throw away cylinders. The gas flow was purely guestimation at the time. I was put off this particular machine since then. I have now decided to dig it out and set it up 'properly'. I will get used to it as Im sure its probably a half decent little inverter for home use.
