That’s really helpful don’t live too far from there. Do you have any rough idea of priceNewton Tesla in Warrington for your motor. B56 frame Imperial Motor
Is this single phase or three phase as I can only use single phaseNewton Tesla in Warrington for your motor. B56 frame Imperial Motor
They do single phase and 3 phase. look on their website under single phase motors www.newton-tesla.co.uk I think they are about £140.00 plus vatIs
You could get an inverter and use the original motor for that much!I think they are about £140.00 plus vat
You could get an inverter and use the original motor for that much!![]()
His original motor is probably 440 volts only so you would need someone to alter the motor to 440/220v for free if you don't know how to do it yourself, then you can use an inverter.You could get an inverter and use the original motor for that much!![]()
Doesn’t matter the pully is too big for the shaft so back to square oneDon’t worry found the perfect motor with the correct shaft size (almost) and the correct hp and speed
From
Machine mart
The motor is 14mm shaftHow big is the pully bore and the shaft? Easy peasy lathe job.![]()
And the pulley is 15.8mm or 5/8”
But the motor shaft isn’t long enough either. The only idea I had was to make a sleeve for the shaft and the pully would need boring out but I don’t have a lathe
