just use powerflow its an acid flux and will solder stainless steel as well https://www.screwfix.com/p/fernox-p...Vp7ztCh02Bgb3EAQYASABEgI1YPD_BwE&gclsrc=aw.ds or any acid flux
I just soldered the pit's in the base of a leaking petrol tank. I put a drop of phosphoric
acid on each pit and dabbed my soldering iron on it, the solder flowed out on to the steel
really nicely.
In the past I used bakers fluid but haven't any left.
What brand do you use and where did you buy it please?
I'm in the middle of a repair on a moth eaten BSA tank and was considering soldering some of the holes in delicate areas. In the past I used bakers fluid but haven't any left.
... the stuff in the tin with a picture on the top of a lord of the rings elf waving a soldering iron around. I don't know if the last one doesn't work as well but I don't like it.
