I was thinking about the LED type, also I believe that you can buy stick on strips that you cut to length. Any thoughts?2 foot fluorescent
Though the LED ones have come down in price a lot and don;t flicker
Thanks I will have a look nowTry tool station, 600mm led batten just shy of£17.00.
Result. I googled Tool station and they have a branch about 2 miles from where I live. Good job I asked the question. You live and learn!!!!!!!!!!!!!!!Try tool station, 600mm led batten just shy of£17.00.
The fatter tubes should still fit unless the manufacturer has pulled a fast one and is not designing to the standard.Tool station do seem to be around the cheapest if you take shipping into account.
I have just been down to buy a 4 foot holder. Sadly I have about 30 spare tubes and they are the thicker tubes that don't fit the new fittings.more searching . Lol
Check first, but most case a simple bit of re-wiring inside the fitting to bypass the starter and ballast removes them from the circuit and saves another little bit of electricity/pounds
Also be aware that fluorescents are not recommended for rotating equipment such as lathes unless they have twin tubes.
They don't mate not on mine.The fatter tubes should still fit unless the manufacturer has pulled a fast one and is not designing to the standard.
What's one of them??Unless you use HF (high frequency) ballast fittings where a single tube would be fine.
