series2
- Cheshire, UK
I recently had to replace my regulator which was a nice BOC type with the output gauge in LPM, it always read close enough to the pea shooter that I could trust the gauge. The gauge on my new SWP regulator lies its ass off, but using the pea shooter on the MIG is a pain as I have to release the wire feed every time I want to check it. After having a little moan at my gas supplier (where I bought the regulator), the gave me a flow meter.
If I use the flow meter as per the instructions, setting the regulator higher than the required flow and adjusting using the knob on flow meter, there is a surge of gas before the flow settles to the set rate. I guess this is because there is a calibrated orifice/jet in the regulator and also in the flow meter. If I open the flow meter valve fully, and use the regulator to control the flow it works as I expect it should.
Or am I doing something wrong?
