Pretty much
remember them . ones I saw had 3 different jet sizes you could useThe valves i used a long time back were just a different size bore on the on the piece that the rubber disc seals against,
hp for mains LP for gravity.....
How it used to be done...... old schoolSort of, but why would you have a tank feeding a tank? Unless it’s properly old school feeding the toilet cistern to stop condensation
In desperation, to shut a noisy cistern up, I fitted a latex glove over the valve and the water flowed out of the index finger. Probably still there.Still lots of old bathrooms on tank feed about. As I remember the type 2 valves are newer and have the top outlet knuckle to prevent back siphonage, I have seen plenty of the old type 1 valves with the tube extended down below the water level to make them quieter. Low pressure bigger hole high pressure smaller hole as stated above.
