not sure if thats the right name for it. what I'm after is a tool the will turn the edge over on a 1/2" pipe so it act like a washer.any info will be appreciated. maybe a tappered end tool of sort that you can use a hammer on .John
The hammer type one, I think you're mistaking the finished result, that one is used to flare a socket "Socket Forming Tool" in 15mm or 22mm pipe to accept a 15mm or 22mm pipe saves on couplings, but it doesn't flare to give a shoulder.
flared,aye that what I mean't. I couldn't think of the name at the time.
what I want is the one that will give a shoulder.
I've been out of the game that long I've forgotten most things that I learn't.
all I've been doing is just welding for the past 15 years with a little fabrication in between.thanks I'll have alook around on the net.
I've had a look but cant see what I'm looking for.its something like in the picture. I only need this one or like to fit into my 20 tonne press. but must be able to put a shoulder edge etc
For what you want you could try this company and request the die set for the size you need. The sets are top quality.... 71700 Hydraulic Flaring and Swaging kit.
