Hi,
Not strictly a project but I guess this is the best place to put it.
i have just bought a small fishing boat. Towed it home about 2 1/2 miles & just as we turn into the drive one wheel falls off. The bearing had seemingly failed & the other one looked very loose. On closer inspection I find that the hubs that are fitted are the wrong ones & only the innner bearings was fitted. The numscull. The problem now is I have a boat & trailer stuck in my entrance drive. I can get in & out as I can go through next door but its not ideal. I did think that it would be an easy pop a new set of bearings in & the local place had the ones I seemingly needed till I found the butcher job previously mentioned. The problem now is I will not re butcher it so need to sort it properly. No probs I thought you can pick up new hubs very cheap online. BUT they are all 19mm or 24mm or 1" & guess what my shaft is 31.5mm BUGGER. Cant find one any where. So do I now have to buy complete new suspension units or should I rip some bits of old kit I have lying around the yard & weld it on? Its only got to get the boat down to the harbour 3 miles away after its been sorted (the boat) & then once per year to bring it back for winter.
Justme
Justme
