wobblycogs
Hi, I've just tried out my new welder for the first time and thought I'd post some pic's of the weld for comments. The welds are onto 20x2mm box section as I don't currently have any scrap sheet to practice on.
Weld 1 was just a guess at settings but looks ok to my untrained eye, perhaps a bit too much power. For weld 2 I lowered the amps but started getting pop corn sounds so for weld 3 I turned the power back up to a bit less than weld 1. The weld then sounded good and I was able to stir the weld pool a bit.
I notice there's quite a bit of brown soot around the weld. I've read that's because the gas flow is too low, I've double checked that I'm running 10 l/m and there's no breeze so I suspect the problem is I didn't clean the work piece before starting welding, it's got a good coating of protective oil on it. Does that sound about right?
Cheers
Cheers
