Hi all!
I managed to get my hands on some Argoshield Light for my Clarke 130EN the other day and have managed a few welds. I started off on 2mm mild steel with some good results on weaving and spot welds. I even managed some OK butt welds with good penetration and a relatively small heat affected area!
I did a few 1mm butt welds the other day and post some photos up below. I've found a nice machine setting of 2, min and 6.5 wire speed which gives good tacks. What I am finding is that when I put a flap disc to the welds I see little pin holes where I put my row of tacks down? Any reason for this? I'm on 10l/min gas flow on 0.6mm wire.
My aim is to be able to weld a new replacement floor pan onto my Vespa 100 scooter. There will be some short weld runs as well as plug welding. The replacement pan measures in at about 1mm and the existing body is 0.8mm. I intend on doing short runs of tacks to minimise warping.
Critique on the photos would be great! Thanks!
The front. bit of blow through on the one weld, not enough power on the other.
The rear.
Front. Middle weld OK'ish, panels didn't line up though!
Rear.
Thanks, Cheers!
Jacques
Clarke 130EN
The rear.
Rear.
Thanks, Cheers!
Jacques
Clarke 130EN
