ill be doing some thin tests soon, i have mainly been adding the strenthening gussets to my trike frame, the bulk of the welding has been done with argosheild so im thinking it should be fine, if i see any signs of fracture during the first few months ill buy some argosheild from somewhere and vee the welds and re do them, i didnt know that co2 makes the weld brittle so ill take the chance this time, well it will probably be the only time as ill not need to build another trike after this one lol, ill post photos of the thin tests when i do someCO2 can make some metals brittle like stainless steel. The Japanese have welded their cars and bikes with CO2 with no problems. Until recently, they did not have any argon supply.
CO2 can add a bit of carbon to the metal. On mild steel there is so little, a bit more wont make a difference.
High-strength steels are a different issue. Adding bit more carbon and the heat of welding can have negative effects that require heat treatment. CO2 does run hotter than argon mixes, so the chance of HAZ effects gets worse.
If I get a chance I'll redo tests with CO2. I had done mix tests before.
Quite what that has to do with weld chill caused by the excellent cooling properties of CO2, is a mystery to me....
Especially since every welding site, gas supplier says CO2 adds heat to the weld via disassociation and the released O2 burning the surface of the weld.
Would more likely be due to added carbon.
If you have used pure argon (I have) you will see it cools the weld much more than CO2 and lays caterpillar shapd welds with a narrow penetration as the argon cools the outer edge considerably.
Have to say that if the Japanese used CO2 without bad effect, maybe it'd be fine anyway? but I do remember some pretty poor welding on 1970s Jap-bike frame though.
Must also say that I think a motorcycle frame made from 2-3mm steel may be a bit on the heavy side, I would have thought 1-1.2mm would be more like it, although Trikes are a different kettle of fish
I doubt your tube frames are mild steel. I have not seen it harden mild steel as it takes a considerable amount of carbon added to make it hard. The little bit added by CO2 does not make much of a difference.
Has been said here many times before, it is near impossible to heat harden mild steel without an ice quench.
You can buy a gas mixer (I have one.)I have a bottle of Pureshield Argon and a bottle of just Co2, is there anyway of mixing the two so I can produce Argon/Co2
(not what i paid though )
