Hi everyone I just bought a gasless mig welder and have actually never welded before in my life! So I set it up and tried it on an old wrench (cleaned) and the weld was awful, there wasn't even anything remotely close to resembling a weld.. nothing but a bad sizzling sound and green spark. closer analysis shows the wire isn't melting into the wrench at all and is basically "exploding" into tiny balls of metal all over the floor, only around 5% of the wire made it onto the wrench and it looks terrible, black burn marks are also all over the wrench. I flicked it to max power and it seemed worse (the wire seems to explode even more and was glowing yellow after use) the wire speed setting doesn't seem to help much either.
It's so bad the wire wasn't even melting at one point I had to stop because I felt the wire feed out into the metal and push the gun back, so I stop to see over an inch of wire extended out of the gun that has failed to melt at all.
Maybe my new welders stuffed? Or the piece of scrap metal I'm using might be no good somehow? If anyone knows anything any advice would be greatly appreciated!! Thanks
