Hi guys,
I've been having a play with my new TIG (TecTig 206i) from Weldequip and have managed to lay reasonable-ish beads on thick steel (old brake discs) as a practice.
I'm using a 1.6mm tungsten (grey tip) and decided to have a shot at aluminium with absolutely no luck! Tried AC, 80% balance, and get a nice ball on the end of the tungsten, and can lay a reasonable shiny weld track as long as I don't try to add any filler.
Trying to add aluminium filler tends to melt the filler rod before it gets to the pool, and tends to leave a dull lump that refuses to melt into the weld pool properly even when I 'run it over' with the arc. Also, when adding filler rod I tend to get lots of soot/crud in the weld, whereas it looks beautiful if it's an autogenous bead.
I'd be very grateful for any suggestions!
Cheers,
David
Cheers,
David
