Ok, so i have done very little welding so far, just my practice welds, repairing a motorbike seat base and welding some flat bar. I finished sand blasting my motorbike frame today and the plates that carry the rear foot pegs and exhausts require repair. One of them isn't too bad but is going to need welding both sides but the other has a section of frame behind it rotting away. I have cut 2 small pieces out of the first hanger and this will require 2 small patch panels but I have had to cut the second one off so I can get to the frame tube. So now i have to repair a section of the frame tube which is about 15mm by maybe 40mm or so. Ideally I need to do it so the plate is not proud of the surface as the hanger has to go back on over the top.
Any suggestions as to the best way to get the patch panel inside and hold it in place to get it welded?
Thanks
D
Thanks
D
