rossdagley
Hi guys.
Thanks for all your assistance so far. I'm finally at the point where I can get some wire down on some sheet to practice and I'd love some feedback.
I've had a play with the settings on my mig, but it's very basic being a Sealey 100 (non-turbo) model. Just Hi/Low and Max/Min for either of those.
I really want to learn so am going on a course in October but I want to get a head start. I have a BOC Y argoshield light bottle, with the recommended dual gauge reg, all plumbed in. It's working well. So - all the gear, no idea now, hence needing your expert comments to help me improve!
Here are some photos showing my first real attempts. I tested on a scrap just to setup the line feed and gas flow, but these are the first actual beads I've tried to run ever so please don't be too harsh!
The runs were done from the outside edge of the plate towards in inside in order of attempts, so my first one is closest to the outside. I experimented only really with hand speed, keeping other settings the same, other than on run 4 where I went to max power. 5 I came back to the setting I'd used before. I noticed a LOT of heat going into the panel on that run - enough to turn the plate orange hot.
The only other thing I'd like advice on is I can sometimes see a "ball" of weld sort of climbing back up the wire every couple of seconds. It soon reattaches to the weld (kinda drops back when it reaches critical size) but it causes the only "cracking" noise in an otherwise quite smooth sounding weld. Is this caused by a setting, or something I'm doing?
thanks for reading this far - your input is greatly valued!
Weld on the right was first ever, leftmost the last attempt.
Trying to show weld height
Rear of plate.
Thanks all!
Rear of plate.
Thanks all!
