Jan
- Rotherham, South Yorks
What an eye-opener! With the power on my SIP Migmate 130 set to 'Max, High' I had to turn the wire feed almost to zero before I got a nice 'bacon sizzling' sound. Even so the penetration on 3/4mm mild was excellent both with the test pieces flat to the heat sink and also up in the open air. Nice!
However I have a couple of questions:
What are the correct dimensions of the shrouds? The current ones seem to be around M7-8 threads and a length of 40mm. Can I go longer with no detriment to the results?
Bearing that in mind does it matter if the tips are then 'buried' deep inside the shroud?
Stand-off: should it be measure from the mouth of the shroud, or should I get shorter shrouds and measure it from the tip?
One of these days I shall weld one thing to another thing and make something else - hopefully a useful something else! We all need to have a goal in this life.
