if its bare metal 2 k acid etch primer is the best. then u can use celly build up primer then celly topcoat then finish with the 2k lacquerI have a quantity of cellulose primer surfacer/filler, & other cellulose paints. Would there be a problem if I used these and finished with 2k lacquer or would I be better in the long run using all 2k from primer to finish?.
TIA
verry truewould be better using 2k all the way , 2k primer shouldnt sink or move about once its cured
but if he already has the gear might as well use it
