julianf
- devon, uk
Currently, i have
a 14cfm direct drive
a 2kw (unsure of cfm) twin cylinder belt drive
a devlibis air fed mask with belt pack (fixed reg and carbon filter)
a devilbis HVLP spot repair gun (cant remember which one - on loan at present, but i can get it back easy enough)
i have no regulators, filters, etc.
There's no point in buying a 3stage filter, right? As i have the carbon pack on the belt?
So i just buy one of these -
The reg, and water trap, and then the coalescing.
But, do i tie both compressors together pre-filters / regulator, so all air goes through the above units, or do i run the setups separate, fit those to the breathing side only, and then duplicate (?) for the gun?
The belt pack, i think, needs to be kept under 7bar.
Also, would i even need more than the 14cfm, for small jobs (single panels, etc) (would be easier with just one unit)
I know ive asked questions about kit before, but this is a new one!
I guess, what id like to hear is -
Buy the unit pictured above, run it on the single compressor, put all air through it, and fit this [xxxx] reg to the gun, and you would be ok for small jobs.
