oceanobsession
What is the correct filler rod method. do you move the torch for instance when
you are doing a but joint.do you get a pool a melted steel do you then push the pool up and down the but joint or do you keep the torch level and in and out with the rod after watching the welding vidio they seem to creat a pool then in and out with the filler rod which ive tried but you get to much heat
and with stainless seems to make a mess of the other side can any off the profestional give me some guidance
cheers ocean
cheers ocean
