One for the bike lads !
Our apprentice at work has an old Cyclocross bike which he is in love with ! Unfortunately the tube that goes between the bottom bracket and the headstock has cracked about an inch away from the lug at the headstock end (apologies for the terminology but I know nothing about bikes !).
He's buying a new frame.
He wants us to weld the old one up for him to use on an indoor trainer (I think he called it a Turbotrainer ??) 'cos basically he can't bear to throw it away !
The weld just needs to stop the crack getting worse. It looks like the frame might be brazed ? We were also going to put a steel gusset in the triangle between this tube, the top tube and the headstock.
I APPRECIATE THAT THE WELD WILL NOT BE STRONG OR SAFE ENOUGH TO RIDE WITH HENCE THE FRAME WILL ONLY BE USED STATIONARY IN THE GARAGE !
Anyway after all that is it possible to Tig Reynolds 531 and if so what's the best filler to use. We'll have a variety of mild and stainless steel filler wires at work.
Thanks in advance !
Garreth
Thanks in advance !
Garreth
