Ashley Burton
- Northamptonhire
Can't say I would want to be involved in this type of job:
Looks like a lot of work!
Its some serious stuff! Wouldn't want it to fall on you, That crankshaft weighed 7.5T in that video!When I was on the Curlew FPSO they refurbed the standby diesel generator, impressive to see a load rated scaffold being built to accommodate a crank!!
I would dread to think how long some of these ship engines run for!My mate is a mechanic on these types of engines, some are so big he can stand in the bore that the piston runs in
Some of his pictures are awesome
A mate of mine was in the Merchant and reckons the greasers job was to stand inside the crank case to grease parts of the engine!
Sounds like a greasey jobI can believe that, I’ve certainly seen pictures where covers can be removed giving full access to the crank, wouldn’t want to be the “greaser”
I always wonder how they torque down the main bearing caps, big ends, cylinder head studs etc, on these motors, and bigger ones.
Can't comment on that but after working in the offshore industry for 10 years a lot of the bolting of flanges etc was done by companies like Hydratight who use hydraulic bolting techniques.
Very true! Diesel engines mainly run at low rpm due to their torque.Some of the biggest engines only turn over at about 120rpm so they can run a lot longer than something screaming away at 3000rpm!
One of my colleagues used to work on boat engines years a go and they had a guy die because he was in the engine and got crushed as someone rotated the crank.
